Cable test in meraki dashboard
Jobsp
Is it correct analysis if we do cable test in meraki switch dashboard rather than doing manual lan tester from end device to switch?
It can help, but the ideal is to do the test with more qualified equipment.
Jobsp
ok. But what does it indicate on cable test like short, open etc?
It will indicate some kind of failure, see the document.
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Using_the_Cable_Test_Live_tool
You get estimated cable length and any open / failed pairs, but it is not 100% reliable.  It is the equivalent of the IOS-XE CLI command to test a cable connected to a port.
