CCTV VLAN & Internet
RCooper
We have a CCTV VLAN that i would like to access over the internet.
Can someone help me with the process please?
Nope, in this case, you have to create in on the firewall or router.
5 Replies 5
who is the gateway from this VLAN? Do you have firewall rules on your network? Do you have more information or a simple topology?
But basically, you need to create a NAT rule.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
RCooper
I am using MS Switches does the NAT rule still apply?
RCooper
OK thank you, I will make the changes on the firewall device.
