- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
C9300-48UXM Meraki Management Onboading Issue
I am trying to onboard some Cisco SKU switches into the Meraki dashboard for management. Everything I can find it tells me that our switches are supported (C9300-48UXM, C9300-48U, C9300-24U).
I am following the Meraki dashboard deployment guide and it tells me that C9300-NM-2Y is a supported network module however I get the following when I run the command "sh meraki compatibility"
1 C9300-48UXM - Compatible 17.10.1r - Compatible C9300-NM-2Y - Incompatible
2 C9300-48UXM - Compatible 17.10.1r - Compatible C9300-NM-2Y - Incompatible
3 C9300-24U - Compatible 17.10.1r - Compatible N/A
I am guessing it is the ios version number, as I look at the release information of that version and it doesn't mention C9300-NM-2Y as being supported but I cannot find which one to use and the documentation tells me to use 17.10.x.
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I don't know the answer.
Try this onboarding process (it is the current recommended one):
https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst/Onboarding/Cloud_Monitoring_for_Catal...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks but I believe that is the process for monitoring and not management. I've been through that process and it went fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can migrate the switch today, just remove the NM-2Y module and then complete the migration process. I've fixed the documentation bug showing 2Y support today.
We plan on fully supporting the 2Y module on the 9300-M by our launch date for the C9300-NM-2Y-M in Jan/Feb. With Early access coming sooner (Dec/Jan). Stay tuned!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Okay thanks, I thought about giving this a try, but I wanted to see if there was a definitive answer. I will give this a try and see how it goes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
According to https://documentation.meraki.com/MS/Deployment_Guides/Getting_started%3A_Cisco_Catalyst_9300_Managem... the C9300-NM-2Y is supported, and i also see it in the Port list - but the device is not recognizing the module. Is there any news to this? a Customer just bought 20 pcs of it and they are not working..
