C-9300 DHCP
AzeemHaider
C-9300 DHCP
Hello
I am using C-9300 stack switches as DHCP server for couple of VLANs, is there any way i can see leased IPs of each VLAN using Meraki portal?
When Catalyst 9300 switches are onboarded to the Meraki Dashboard in “Monitor-only” or “Device Configuration” mode, their DHCP server function remains local (IOS-XE), the Meraki Dashboard does not have visibility into DHCP lease tables from the switch.
Ryan_Miles
Meraki Employee All-Star
Navigate to the Switch then click on the DHCP tab. That will show the scopes defined, used & free, percent of utilization, and in the lower section all the individual leases are displayed.
Haven't tested, but these API endpoints might provide the data as well.
https://developer.cisco.com/meraki/api-v1/create-device-live-tools-dhcp-lease/?
then
https://developer.cisco.com/meraki/api-v1/get-device-live-tools-dhcp-lease/
GIdenJoe
If you are running in native ios-xe mode you can just use the commands.
show ip dhcp binding
AzeemHaider
I just went "Network-wide" --> Monitor --> Client --> and sorted out IPV4 address column and got leased IP list,
thank you all
