Block Non- complaint devices to access services in LAN network using NPS.
Tariqmahmood
Is it possible to block non complaint PCs in LAN network to access other resources for example in Azure.
We have VMs in Azure and want non-complaint device not to access them through wired LAN network. We have meraki switch and MX appliance and NPS server in Azure. any practical link for such setup will be appreciated. Thanks
Scenario: If a person comes with his personal PC and connects to switch port configured with CORP-network VLAN he should be directed to Guest vlan rather CORP. For wireless i know we can do that but not sure about wired network.
2 REPLIES 2
Well, you can use access control configurtion on the MX:
https://documentation.meraki.com/MX/Access_Control_and_Splash_Page/Access_Control
Or if it's possible you can use 802.1x on Wired, but your siwtches need to support it. Here an example:
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)
Like @alemabrahao says - I would be looking at wired 802.1x.
