Hi there,
Hope you’re doing well.
it’s possible to automate the changing password of the devices with and API?
kind regards,
Josue Gaytán
Which password are you referring to?
Hi Philip,
for example, for the enable and user administrator password for the C9300-XX-M model or the catalyst monitoring switches.
When in Meraki managed mode there is no enable or user administrator username/password.
That implies you are using Meraki monitored mode. You can either use the traditional Cisco REST interface with YAML, or SSH.
