Aggr port numbers
Umut_Destan
Aggr port numbers
How do you determine which ports are aggregated for example inside Aggr/5 ?
Is there a list somewhere?
6 REPLIES 6
If you click on one of the switch ports it will tell you.
You can also go Switch/Switch Ports and see it there.
BrechtSchamp
Go to the Switch > Switchports and enter "is:aggregated" in the filter box at the top. It'll list all aggregated ports. In this example port 9,10 are part of the aggregation.
Edit: Darn it, too slow.
Thank you for the quick replies.
I can list all the aggregated ports using "is:aggregated" .
But my problem is learned their respective AGGR/X , x being the aggr port number.
So I can not determine for example what ports are aggregated as AGGR/5.
I'm trying to find the physical port of a client. I find the client and click its port, and it's listed as AGGR/5.
I would like to follow this path and find the ports that compose AGGR/5.
Unfortunately clicking AGGR/5 gives me an error recently.
That should work. It's probably best to open a support ticket to have them take a look at it.
Thank you Brecht, I will open a case for this.
Was just wondering if there was a page listing the AGGR/port numbers somewhere, because I wasn't able to find it.
Anyway, I think there isn't a page for this.
I'm afraid there isn't indeed.
