Presumably same issue as your APs the other day. You have vlan 13 set as native, but you're also tagging it in the static IP for the switch. So, delete the VLAN field under the switch mgmt IP config.
Ryan / Meraki SE
If you found this post helpful, please give it kudos. If my answer solved your problem, click "Accept as Solution" so that others can benefit from it.
