One point I would bear in mind is that however you implement the solution you eventually deploy, you should avoid routing multicast through a Meraki MX security appliance/router, as, in general, a number of multicast services such as an IGMP-Proxy, have not yet been implemented.
Meraki switches are more multicast capable, but I would still trial a couple of their switches prior to committing to any specific hardware. I have found, with multicast (video and audio) that actual implementations of multicast services are variable and that end devices can have quite specific requirements which are not always immediately apparent.
I prefer to isolate multicast traffic from other network activity by extensive use of VLANs, avoidance of native LANs and implementing explicit, generally non permissive, switchport profiles on all ports. A little fiddly to set up but it pays off every day thereafter.
