Access policy dot1x/mab with authentication open
mirkomaffioli
Just browsing
Dear community,
I'm working on a wired authentication project based on Cisco ISE as radius server and Meraki MS210 as access switches.
I'd like to start applying a behavior similar to the "authentication open" of the legacy Cisco world then move to the "authentication closed" but can't find the equivalent in the Meraki dashboard.
Is there any "hidden" way?
Thanks,
Mirko
1 REPLY 1
you  can use the guest vlan fallback to put the cliënts in the vlan if they fail authentication. not sure if that is simalar behaviour.
