ACL logs
idknow
ACL logs
Do you guys know if there's any way to get logs from ACLs configured on meraki switches, because nothing shows up from the dashboard ie "event log". And let's say if i set up a syslog server would it be the same ?
3 REPLIES 3
KarstenI
No, Switch ACLs are processed in hardware, but logging would involve the CPU to send them. If you need logs, the firewall is the place to go.
oh ok i get it, but the thing is, intervlan routing is operated by the ms switches and where acl rules also sit. We have a non-meraki firewall upstream only to route outside
KarstenI
Well, you can't have both. Either you move your clan-routing to that firewall or you accept not to have logs.
