Video egress/download APIs
chris-terminal
Hi. Are there an APIs available to extract stored video from any of the smart cameras? We would like to automate the process of downloading video segments when a motion alert or object detection event occurs.
Thanks,
Chris
Hi @chris-terminal
Unfortunately there is no API to extract/download the videos. Her you can check all the APIs available.
https://developer.cisco.com/meraki/api/get-device-camera-custom-analytics/
GreenMan
Meraki Alumni (Retired)
If you need to push footage out to an external system you'll want to use RTSP:    https://documentation.meraki.com/MV/Advanced_Configuration/External_RTSP
You can use the Dashboard API to push a still image or images from a camera though, as a result of (for example) a detection event, which allows quick review  of an event - plus all sorts of integrations involving AI/ML analysis:   https://developer.cisco.com/meraki/api-v1/generate-device-camera-snapshot/
@GreenMan has covered it well.
Other options you could consider;
