Video Wall
GB_CBSI
Video Wall
Apologies, if this has be asked / answered in another thread ....
Is it possible to make a video wall with selected cameras from different locations?
Best
GB
jdsilva
Hi @GB_CBSI.
You can only make a video wall from cameras that are in the same Meraki dashboard network. That said, you can have cameras that are in different sites or locations part of the same network, thereby allowing you to create one video wall with them.
GB_CBSI
Awesome, thanks...the same camera can be in two different dashboard networks?
All lobby doors on one wall while also residing in its own network?
thanks
GB
jdsilva
Nope, they cannot be in two networks at once.
You could create a "Lobby Doors" network, and then put all the lobby door cameras at all locations into that one network.
Or, just put all your cameras no matter what into one network, and then build video walls any way you want.
