Template for Security Cameras
Just browsing
Was wondering if there is a way to create a template for security cameras similar to what you can do with networking? Will be installing multiple cameras at multiple sites and would like a simple way (for my install crew) to make sure they are all configured the same.
Accepted Solutions
Re: Template for Security Cameras
There isn't a way to template cameras. I have been making wishes for this for a while...
1 REPLY 1
