Rain protection - MV63 on L-Bracket Mount
Max_C
Hello all,
We have installed MV63 on pole with L-Bracket Mount and we have a lot of problems with rain.
There are water drops on camera and it's not possible to see correctly (specially to check license plate numbers on car).
Do you know any accessories that can be used as a rain shade/shield ?
Regards,
2 Replies 2
GreenMan
Meraki Alumni (Retired)
 I've had really good results just from using Rain-X spray
BHC_RESORTS
I can't believe I haven't thought of this. So simple yet we've been struggling with the same issue and were going to custom make some hoods for various cameras. This should be much easier!
BHC Resorts IT Department
