MV schedule changes
SoCalRacer
MV schedule changes
Is there a way to change the schedule on a camera without using the dashboard? I looked through the API and can't find one. The reason I ask is we have motion alerts turned on with a schedule. The problem is that it seems regularly that motion is detected and we get bombarded with alerts when something scheduled is going on near that camera. I would like to run a script that would disable alerts or lets say mute 4 hours or until I turn them back on. Any ideas?
2 REPLIES 2
jdsilva
I don't play with cameras too much... But can you modify  the Custom recipients for motion alerts field with the Alerts API Endpoint?
https://api.meraki.com/api_docs#update-the-alert-configuration-for-this-network
Could you just clear the custom recipient list for the times you don't want alerts?
I live @jdsilva's answer.  Another potential option is the email system you use may allow a mail rule to be configured on a schedule.  So you could must move/dete the alert emails between certain times.
