Thanks I know but that needs additional licensing as well to an already licensed device. I would compare it to MR licensing. Every AP works with the same enterprise license. You have the option to choose advanced license if you like to have more security with umbrella.
MV2 is quite expensive, require same license as the other MV’s. But are more or less “useless” without cloud archive. It’s a little bit annoying you cannot even go back 10 seconds in time.
just using the MV2 for lab purpose. It’s cute and all but if I would like to see stuff in realtime I would buy an Eufy cam for 25 dollars that display video in realtime instead of up to one minute delay.
I love the whole Meraki platform and products and that is probably the most and only negative thing I would express.
I have never used cloud archive or seen it as it seems you cannot get a trial for it. I have not succeeded with that anyways.
thanks
