Liquid detection would be the MT12. Stick the MT10 in liquid and you're bound to have a bad day.
As for the MT12 its primary targeted use case is to be dry and when liquid contacts the leak detection cable send an alert. Not sure we've tested the reverse in which the cable spends its time wet all/most of the time.
What would you be monitoring here?
Ryan If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
