Dashboard reporting all MT40s as Dormant. Oh no they're not!
sungod
I'm not sure when it started, possibly post the 2.0.1 firmware upgrade back in August, but that's a guess.
No config changes to the Org in the last two weeks, no WAN/device outages, no alerts.
There are four MT40s on a network, all are live and providing data within the last few minutes, but Dashboard says they're all Dormant, which clearly is nonsensical.
There's an MT14 on the same network, that shows as Online.
On the off-chance, I just rebooted the AP they are all using to connect, now they all show Online.
Has anyone else seen this behaviour?
I'm tempted to swap out the AP - it's the only one on the network and only the sensors are using it.
Edit: I just checked, now Dashboard says they're all Dormant again! Which I believe makes it a Dashboard problem - as if they were reported as online a few minutes ago it's clearly impossible for the Dormant time to be reached.
6 Replies 6
You know what you have to do.  A painful support case.  🙂
I'm having fun with an errant CW9166I that showed dormant when it rebooted for a firmware upgrade.  I refreshed the page and it showed online...  Now correctly showing offline then online as it boot loops...
sungod
I steeled myself with another glass of tawny port, and opened a case.
Ryan_Miles
Meraki Employee All-Star
Could be a 30.7 issue. May want to test the latest 31.1.5 or have Support roll you back to a 29.x version at least to test.
sungod
Just a fyi for anyone seeing similar, the issue has bubbled through the layers of support and is now with the Meraki engineering team.
sungod
Meraki report this has now been fixed, and I can confirm I've not seen any false offline/dormant status for several weeks now.
