vMX100 VPN-hub
Stefan_Tabell
vMX100 VPN-hub
Dear Colleagues,
I have a question about the VPN-hub, firewall and OSPF function of the vMX100.
If I have MX64 and Z1 at the branches connecting with VPN-tunnels to a vMX100 in Azure with OSPF Advertise remote routes enabled, does this mean that that it will advertise the routes it learns from the branches will be advertised back to the branches over the tunnels?
For example:
Site A - vMX100
Site B - Z1
Site C - MX64
B --- [VPN] --- A --- [VPN] --- C
Will site B learn about the subnet in site C without static routes configured anywhere?
Is there any possibility to add L3 firewall rules between these from the vMX100?
GreenMan
Meraki Alumni (Retired)
By default the branches (spokes) will learn the routes for all the other branches (though it doesn't actually use OSPF to achieve that - they would still be able to reach them, even with OSPF disabled).
It is possible to have Support configure a back-end setting to prevent spokes from learning about subnets at other spokes, if you so wish - in some large solutions, this saves resources on the 'smaller' MX models.  bear in mind - even with that configured, if you advertised a supernet which included all your branch subnets, from the vMX Hub, each spoke would still be able to reach other spoke.
You can indeed filter the traffic flowing over the AutoVPN tunnels though, even if the routes are available, using VPN firewall rules, configured under Security appliance > Configure > Site-to-site VPN
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
Remember too, when using OSPF - it's a one-way street;  the Spokes do not automatically learn what subnets you're using for your services, within the cloud DC.  You have to configure those as Local networks at the Hub.
1 Reply 1
GreenMan
