vMX Firmware upgrade process
Bolenath
We have installed vMX in Azure on version MX 18.211.5.2, and would like to upgrade the firmware version.
Can we directly upgrade Firmware from Meraki Dashboard or we need to redeploy the vMX?
Can you help me with the exact process of upgrade?
Bolenath
JamesT91
The process is the same as upgrading any other Meraki device from the Firmware menu in dashboard.
Managing Firmware Upgrades - Cisco Meraki Documentation
6 Replies 6
JamesT91
Bolenath
so that mean from version 18 to 19.X looks not a major upgrades so we can directly from Dashboard? Not required of redeployment of vMX right?
Amit_pal
Yes , that's correct ... We did upgrade recently to 19.1.9 and you don't have to redeploy any thing ... it's same as MX upgrade
rhbirkelund
In terms of firmware there should be no problem in upgrading from MX18 to MX19. Both major trains are supported.
That being said, what is the vMX you have installed in Azure? a vMX100 or the newr vMX-S/-M/-L?
It it's a vMX100, you may want to consider looking towards migrating to the newer vMX. But this will require destroying your vMX100 and provisioning a new one.
Bolenath
Installed in Azure of vMX-S
Then you can do the normal upgrade process without having to reinstall vMX without any problems.
