I have a question about vIP of MX setting.
When I set vIP, It have to put IP address.
In this case, If I set vIP should I get static IP from ISP ?
If I get only dynamic IPs(no static IP) from ISP, How can I set vIP ?
Thank you,
your ip range assigned by isp can change?
how many ip' s you have bought from isp?
Thanks ww for your answer.
I think I can get /29 ip address(Dynamic IPs).
Thank you NolanHerring,
But my question was not /29 bit issue.
I'd like to know that whether it needs static ip or dynamic ip when I set vIP.
There are two types IP(static ip and dynamic ip) in Public IP.
Static IP is more expensive than Dynamic IP.
Thank you,
@kuniyes, you need static IPs (a /29 as @NolanHerring has shown) for the virtual IP setup.
