split vpn traffic / dns resolving
Kieshan
How can I split the network traffic on a vpn connected client ( windows 10).  The client should use the company DNS to access shared folder. Other traffic e.g. streaming, social madia etc. ( non company purpose should resolve trough the client home router.  I have a meraki mx64 with no AD integration.
please help/suggest
Nash
Try @PhilipDAth's PowerShell script generator.
Once you've got the script put together, you'll need to re-install the VPN on your end user's computer(s) using the script.
1 REPLY 1
Nash
