site-to-site VPN settings
diablo24
In the API docs it shows the following:
  "mode": "spoke",
  "hubs": [
      "hubId": "N_4901849",
      "useDefaultRoute": true
      "hubId": "N_1892489",
      "useDefaultRoute": false
  "subnets": [
      "localSubnet": "192.168.1.0/24",
      "useVpn": true
      "localSubnet": "192.168.128.0/24",
      "useVpn": true
In the spoke mode you can get which hubs its connected to. Is the "hubId" the networkID of where the hub is located? Or is just a random string that's generated? Also, if the FW is the hub, is there any way to find this ID if its not the networked ID? I'm writing code to stitch up VPN connections and its difficult to associate hub and spoke without some unique identifier.
This is what I have when the FW is setup as hub:
    "mode": "hub",
    "hubs": [],
    "subnets": [
            "useVpn": true
            "localSubnet": "137.68.11.0/24",
            "useVpn": false
            "localSubnet": "101.11.10.0/24",
            "useVpn": true
MerakiDave
I'm not sure about those hubId numbers, they don't look like typical network IDs.  When I run the command https://dashboard.meraki.com/api/v0/organizations/<org-id>/networks in Postman for example, all of the network IDs are either L_ or N_ followed by 18 digits, so I'm not sure about those 7 digit identifiers, I'll try to check into it and let you know.  But run that also in your environment and see if there seems to be any correlation.  I looked through the updatevpnsettings function https://github.com/meraki/provisioning-lib/blob/master/python-3.5-api-module/merakiapi.py and don't think it's giving any answers on where the hubId is generated from.
diablo24
Thanks @MerakiDave
Unfortunately, I don't have a hub to connect to when I place my FW in spoke mode. So I'm unable to see the output.
diablo24
@MerakiDave- Just following up to see if you found any other info on the hubId.
Thanks,
-Jerome
ITCaM
4 years later, I came across the same issue. For anyone else that stumbles across this thread. The hub id is the network id that the hub resides in. Just spoke with support and ran it for myself. Works a treat.
