Search instead for
setup meraki and azure mfa
how to setup a meraki vpn to azure MFA on-perm server
11 REPLIES 11
Re: setup meraki and azure mfa
You need to deploy Microsoft NPS on-premise, then install the Azure MFA plug into NPS.  The you can point the MX to the NPS radius server to do the client vpn authentication.
Just browsing
I trying setup MFA server with meraki
I setup it as radius server point to meraki then I point meraki to it  and it gives me the error a radius message was received from an invalid  radius client  ip which point to the meraki
The MFA server is very simple configure just need to enable radius and point to firewall what am I missing
I do not want to use the extension for nps since 1 it does not work and second it very limited
You don't point the MFA server at the firewall.
You add the MX as a client of the RADIUS server.  Also you will need the client configured to use push notifications.
Just browsing
Anyone have steps by step how n how get this configure there not munch online
Thanks in advance
Just browsing
Any steps on how to get this configure
There not much online
Just browsing
Any steps on how get this configure There not much documentation online
The reason why there isn't much effort is Microsoft have only made a half-hearted effort at providing MFA outside of the core Office 365 family of products.
You might want to consider one of the more serious MFA providers like Duo.
Just browsing
I need to authicate against azure users  or Windows AD does duo do that and is it free( prefer Azure logins)
No it is not free - but it is a fully fledged MFA.
Just browsing
Great to hear. I will keep in mind
If anyine know steps nos and mra server configuration I will greatly appreciated it
Just browsing
I found out that Duo is cloud base solution therefore we can not use it in our environment.
I need an prem solution or steps for NPS?MFA server, please
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
