We have a few MX68 and i'm seeing the same issue. I've logged a call with support. Feedback is the customer didn't use any applications. 80% of our traffic is to microsoft for mail
Hope you're doing well, Apologies you are actually right what I will do is investigate this to see if its a widespread problem internally I will notify you on further updates on this issue.
I have enabled Traffic analysis 4 days ago and have the exact same error messag "No data collected". We're around 25 people connected to the network and around 100Gb of data is going through the Firewall everyday. I can't believe no enough data is collected.
I can confirm that our dashboard is showing stats again
So if your's is still broken log a call with meraki to check
Dear Wickus,
There was a maintenance window that took place to resolve this issue on Tuesday 17 December. The issue has been resolved let me know if there is anything else I can help you with. If not this case will be closed.
Thank you for your patience.
Kind regards.
-- Mahad Gaal Network Support Engineer .ılı.ılı. Cisco Meraki
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
