new MX450 Visio stencil
Lupe
Putting a drawing together and need to show all  interfaces and links on the new MX450. I eed the new MX450 vision stencil, I have been looking for it but just can't find the updated visio stencil that contains the new MX450. Anyone know where I can find it?
Thank You!
4 REPLIES 4
Adam
I usually make my own by grabbing the device image.  ie https://meraki.cisco.com/img/products/appliances/mx450/mx450-mantle.jpg
Then making the background transparent and resizing.
MerakiDave
Unfortunately the stencils are not updated often enough, this is the current stencil file https://meraki.cisco.com/lib/cisco_meraki_visio_stencils.vss so I will ask around for when we can expect an update.  If product images are helpful, they are more up to date and available here https://meraki.cisco.com/library/product-images
WilliamQin
Hi  Lupe
if you need draw topology, you can to Cisco website download the Meraki icon, That Has vision version icon,
please see the link https://www.cisco.com/c/en/us/products/visio-stencil-listing.html,  open the link, search keyword Meraki download the icon.
I hope to help you.
CarolineS
Community Manager
Hi @Lupe -
We've just released a new stencil set, in draft form - it includes an MX450. See this post for more info. Feedback is welcome!
Cheers!
- Caroline
Caroline S | Community Manager, Cisco Meraki
