need to block java.exe file download
Happiman-v2
MY company needs to block downloading any versions of java.exe file from the Internet. What could be the easiest way? I thought about creating a hashing file to match & block but Meraki supports says that's not possible. Hash file is for only to allow files when they are blocked by mistake. Any ideas do guys have?
2 Replies 2
DarrenOC
Hi @Happiman-v2 , maybe take a look at Umbrella SIG.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/design-zone-security/umbrella-desi...
BlakeRichardson
Looking at this from another angle can you block this application via your antivirus software?
