I was told that the MX65 merkai security device did not support LLDP for Polycom VVX phones for VLAN. is this correct ? and if it does what am I doing wrong 🙂
Solved! Go to solution.
The MX65 supports LLDP, and LLDP will be use for PoE negotiation. However it does not support advertising a voice VLAN via LLDP.
