meraki mx84 and mx64 vlan trunking
kenji
hello
 we are using mx84 sdwan in our main branch and in our sub offices we use mx64 sdwan
in mx84 we set vlan10 192.168.10.x/24, and vlan20 192.168.20.x./24
can i cascade or trunk this in our mx64 , using the sdwan/vpn connection
kenji
thanks , is there any solution that i can use the other vlan in sub offices?  via meraki sdwan?
8 Replies 8
Brash
No, the Meraki SD-WAN is an L3 VPN connection. It doesn't bridge layer 2.
kenji
Brash
There is not in the Meraki world, but realistically it is a very poor network design to extend layer 2.
It's typically only seen with datacenter interconnects using a technology like OTV or VXLAN.
Is there a specific reason you're looking to extend your layer 2 between sites?
kenji
our voip , need to be in the same lan segment , our company uses yeastar pbx , its ipphone doesnt connect to the yeastar server if the ip's is not same with its lan segment , btw thanks for the info
FabianSchleef
maybe you should get some VoIP Service consulting to get a scalable solution instead of doing network experiments. 🙂
kenji
thanks , 😅
BALAJIRG
kenji
thanks
