I've got two MX105's in a hot spare setup along with a number of MR46 Access Points.
On the MX105 logging is enabled for flows and URL which goes to a Graylog server.
If a PC that is physically plugged into the network goes to a website I can see the source IP address of the PC and the destination IP address of the website (using Graylog). However, when the same PC is wirelessly connected to an Access Point the source IP shows as the Access Point, not the PC.
Is there any way for the MX105 to report the wireless clients IP address instead of the Access Point (if it helps, both wireless and wired networks are on the same VLAN)?
The reason for asking this forum is because the logs are coming from the MX105 but I do realize that if there is a setting for this it may reside on the MR46 so I'm hoping there is some crossover between forums.
Thanks,
