group policy per vlan and switch setting
ciscofan1
I have 3 vlans, 100,200,300.  i want to apply different group policies on the MX.  For internet routing on the switch, it has a default gw 0/0 pointing to the MX IP on VLAN 100.
How do i route each vlans internet traffic to go through the per VLAN group polices defined on the MX ?
The switch is Cisco 2960 which can do basic routing.
You will need to move all three VLANs to the MX (so the 2960 is not doing any routing).
Then following this guide:
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Poli...
ciscofan1
thanks but what about the ip helper address...its a server on one of these vlans...do i plug this helper address on the switch svi ?
You can configure this on the MX as well.
