group policy per vlan and switch setting
I have 3 vlans, 100,200,300.  i want to apply different group policies on the MX.  For internet routing on the switch, it has a default gw 0/0 pointing to the MX IP on VLAN 100.
How do i route each vlans internet traffic to go through the per VLAN group polices defined on the MX ?
The switch is Cisco 2960 which can do basic routing.
3 REPLIES 3
Re: group policy per vlan and switch setting
You will need to move all three VLANs to the MX (so the 2960 is not doing any routing).
Then following this guide:
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Poli...
thanks but what about the ip helper address...its a server on one of these vlans...do i plug this helper address on the switch svi ?
You can configure this on the MX as well.
