failover over the autovpn
jOMeraki2
replicatiom.pngHello everyone, I have two mx that are connected to each other using an AOTuO VPN, each in a different place.
On site 1 I have a hyper-V host, and on site 2 I have a replica.
Thus, in the event that host 1 goes down, how can I replicate virtual machines on site 2 using the same subnet? Can I use Meraki for this, or are there specific devices involved? what aboute vxlan and how to apply it
Both MXs must be Hub.
Take a look at the article.
https://meraki.cisco.com/blog/2014/07/now-in-the-mx-high-availability-for-datacenters/
You would need to use a unique subnet on each site for replication (create a dedicated replication VLAN on each site, and replicate VMs over that).
You can't do layer 2 LAN extension like this and have both 10.200.5.0/24 subnets both hot.  If you wanted to failover between sites, you would need to go into the Meraki dashboard and move the subnet from one MX to the other MX.
Meraki has no native VXLAN support.
