eBGP with Meraki MX
engineeringmike
eBGP with Meraki MX
I'm looking to create a BGP peering between my LAN switches and the MXs (directly connected). It appears Meraki only supports peering through the WAN interfaces, is that so? Would I be able to put a LAN IP on WAN2 and peer with the LAN switches?
Another question - how do I select which routes to receive and advertise through BGP?
engineeringmike
For anyone facing the same issue I did, choosing Default as the source interface allowed me to create the eBGP peering with the LAN.
5 Replies 5
RWelch
Border Gateway Protocol (BGP)
Not sure if it'll help but scenario 4 and 5 might be of assistance to you.
Have you checked this document?
Border Gateway Protocol (BGP) - Cisco Meraki Documentation
engineeringmike
Thanks for linking that document. I see this line
"eBGP peer relationships are supported on both the WAN and LAN of the MX, peering is bi-directional and routes will be automatically redistributed into AutoVPN."
However, I don't have an option to peer on the LAN in the settings even with the MX operating in routed mode
Take a look at this part.
https://documentation.meraki.com/MX/Networks_and_Routing/Border_Gateway_Protocol_%28BGP%29#Scenario_...
engineeringmike
