detection host on LAN
How can I detect that a suspicious  host has been detached to a LAN network ?
3 REPLIES 3
Re: detection host on LAN
I'm not sure what kind of "suspicious" you mean. But here's a few points:
  • IDS/IPS and AMP events would be found in the Security & SD-WAN > Security Center
  • Rogue DHCP servers would be found in the Network-Wide > Event Log
  • Sticky MAC breaches would also be listed in the Network-Wide > Event Log
  • You can also set alerts to warn you if specific MAC-addresses connect to the network. You can do that in the Network-Wide > Alerts page.
Does any of these answer your question?
How to detect that a foreign host has been connected to my network, and how to prevent him from gaining access?
Preferred way to do this would be to implement 802.1X access control:
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)
