client vpn mx84
FishMan
client vpn mx84
i have a problem with vpn. i can connect to vpn and go to internet but can't access to my share folder on server.
my mx84 meraki connect to cisco nx3548 and my servers are connect to NX3548
hope you can help
2 REPLIES 2
MilesMeraki
If you can successfully connect to the Meraki client VPN, the issue appears to be with the MX to the File server.
Are there routes present to allow for the traffic to and from the Client VPN? Are there any ACLs/Firewall rules that could be blocking the traffic?
Can you ping the file server?
Is Windows Firewall on the server allowing traffic from remote subnets?
