hi,
i have a cisco router rv345 ( 16 ports)
current setup ( gui only not familiar with cli) :
- 2 wan connections
- 1 coax 350mbps as the primary connection
2- lte router max 5mbps only to be used for backup
- 3 vlans ( on separate subnets 1 2 &3 )
how do I configure the router so that the second wan ( slow lte connection) only serves say vlan 3. is there an easy way that would save me from having to learn cli?
