Z4C Teleworker GWs with Templates and Wifi Settings
COtto
I'm configuring a bunch of teleworker gws via configurations templates - mainly the wifi ssids. After setting up the first 2 GWs i wanted to change some wifi settings like disable 2.4 Ghz radio and stuff like that. But it seems like thats not possible in the template nor the actual network - because these options are just missing.
Am I just bild to find it or is that not possible when using templates?
thanks,
Christoph
thanks,
christoph
1 Reply 1
GreenMan
Meraki Alumni (Retired)
Even for an individual Network, rather than a Template, disabling specific bands requires a call to Meraki Support, for a back-end change.
