Hello everyone,
Two questions:
1) Should I use Z3C-HW-WW or Z3C-HW-NA for Mexico?
2) Anyone knows if Z3C is been certified to work in Mexico?
Thanks a lot!
Solved! Go to solution.
Yes, actually I did and said it has been completely tested in Mexico. The correct part number for us is North America.
Regards
I would suggest that you contact your Cisco Meraki sales rep, they may be able to answer both for you.
