Z3 Support Dual HUB and spoke topology and local internet breakout
Mohamed_Rabee
Hi ,
Does anyone knows if Z3 supports double Tunnels to dual HUB simultaneously in HUB and spoke topology ?
what kind of security protocols are used between the remote and the HUB ? IPSEC or SSL/TSL ?
does it support local break out to Internet , forward some traafic to VPN and other traffic such as Iaas (office356) directly to Internet using the WAN internet link ? and if this is supported using static routing or it supports application-based routing ?
1 Reply 1
Dual Hub: Yes
Protocol: IPSec
Local Breakout: Yes - but no security features (such as content filtering).  Everything that does not go over the VPN will go to the Internet (assuming you are not using full tunnel).
