Writing a FW Rule Meraki M-84
DannyR76
I have configured layer 7 geo blocking rules. There is one server in Germany that I need to allow access and I'm not sure how to go about it. Or I should say what the best way to go about it is. I mean I can always unblock Germany but that's not what I would like to do.
I know the server's URL/domain, the ports, and the IP address. What's the best option? A layer 3 rule or a layer 7 rule? What would the rule look like? I should mention I use Umbrella (OpenDNS) but I can't see that would affect anything.
Firewalls and rule writing are not my strongest abilities...
You can't override a geo rule.  You will have to remove the country to gain access to that server.  There is no other option.
DannyR76
OK, Thanks Philip. Appreciate the quick answer.
MarkB2
Please submit a feature request telling Meraki you need this feature, its basic firewall stuff
DannyR76
Great idea. I will do that.
