Wireless Client-to-Client Access on Stand-Alone MX64W
PaulDavis
Is it possible to prevent client-to-client access on an SSID using only a stand-alone MX64W?
And Is it also possible to allow client-to-client access on a different SSID using only a stand-alone MX64W?
Thanks,
Paul Davis
To prevent clients talking to each other you need the client isolation feature - but this is not supported by the built in AP's. You need a standalone MR.
Yes you could allow clients on different SSID's to talk to each other.  The easiest way would be to bridge both SSIDs to the same VLAN.
1 Reply 1
