Which speed is supported with MX105 mgig port?
siyzhao
Hi experts,
Anyone knows which speed is supported with MX105 2.5G mgig port?
In my opinion mgig should be 10/100/1000mbps, but never seen 10mbps on MX.
Is it 100/1000/2500, or 10/100/1000/2500?
5 Replies 5
Brash
I believe the MX95/105 models support 1Gbps & 2.5Gbps on the mGig WAN ports.
That's basing it off the RJ-45 LED behavior here - https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/WAN_behavior_on_MX75%2F%2F85%2F%...
That said, I've never tested so can't be sure.
KarstenI
To my knowledge, 10Mbps was abandoned by all vendors on MGig ports. But I never tested it.
It certainly doesn't work on any Cisco device I've tried, or any Broadcom based port...
siyzhao
Hi cmr, in MS switches, RJ45 port can support 10/100/1000BASE-T, that's why I'm hesitant about the speeds supported by mx.
@siyzhao the mGig ports on the MS355-48X and the MS130-12X both only let you set negotiation down to 100Mbps.  I'm 99% sure we had to use the 1G ports for 10Mbps devices when we replaced the old Cisco 3850s.
