Warm Spare
ehsan230564
Warm Spare
Dear Sir,
After creating warm spare between two Meraki MX64, the SPARE is unreachable. Both the Meraki are connected to a switch by their lan1.
CptnCrnch
What exactly do you mean by „unreachable“? For the dashboard? For you to ping?
AjitKumar
Hi@ehsan230564
"SPARE is unreachable" means the secondary device is not reaching the  Meraki Cloud with the "Physical IP".
Could you please re-check the IP Addresses configured on the Secondary MX and internet access is allowed for the same?
How about this?
Delete the primary device from the network and check if your spare is coming live?
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
They both need to connect to the Internet via a WAN port.  They should have different IP addresses on their WAN interfaces.
Is this the case?
