I have a customer that is familiar with the Fortinet solution and asked if the MX devices support Virtual Domain, if so can you please share this so I can send it to the customer.
Solved! Go to solution.
I doubt it is on the road map.
Nothing to share here. There‘s no equivalent on Meraki.
Thanks for your quick reply, just to be clear. It's not supported but is it something in a roadmap?
Thanks Guys
One last question, So if they wanted to do a IPS or separation of internal and external firewalls that would have to be done by 2 separate devices?
If they wanted seperate internal and external firewalls they would need two physical devices.
IPS could be done on both or either.
Thanks!
