Virtual Domain
Eddie01
Virtual Domain
I have a customer that is familiar with the Fortinet solution and asked if the MX devices support Virtual Domain, if so can you please share this so I can send it to the customer.
I doubt it is on the road map.
7 REPLIES 7
CptnCrnch
Nothing to share here. There‘s no equivalent on Meraki.
Thanks for your quick reply, just to be clear. It's not supported but is it something in a roadmap?
Thanks Guys
One last question, So if they wanted to do a IPS or separation of internal and external firewalls that would have to be done by 2 separate devices?
If they wanted seperate internal and external firewalls they would need two physical devices.
IPS could be done on both or either.
Thanks!
