VPN setting with non-meraki VPN hub and all MX spokes
play_trumpet
Hi all,
I'm considering VPN configuration with following topology.
Branch1(spoke/MX)------+     (    )
Branch2(spoke/MX)------+  (         )  + DC1(Hub/ASA)
Branch3(spoke/MX)------+ (Internet)
Branch4(spoke/MX)------+  (          ) + DC2(Hub/ASA)
Branch5(spoke/MX)------+     (    )
MXes on Branches only need to establish S2S VPN connection to DC1 and DC2.
i.e. No VPN connections between branches are required.
Now I've tried to configure non-meraki VPN peers while disabling auto-VPN feature by setting VPN Type to "Off". But non-meraki VPN setting menu appears only when I set the Type to "Hub(mesh)"...
* GUI Example1: When the type is set to "Off"...
* GUI Example2" When the type is set to "Hub"...
Is it expected result?
Could anyone tell me how to configure S2S VPN sessions like the topology?
This is the expected behaviour.  Actually only one has to be in hub mode and the others in spoke mode however this will result in the branches having a VPN built between themsleves.
This is also a really hard way of doing this.  If you have less than 50 branches you could put a low cost MX64 or MX67 into each DC in one arm VPN concentrator mode, and use AutoVPN instead to solve this.  It would be a lot less work, and you would gain the benefits of SD-WAN, monitoring and visibility.
https://documentation.meraki.com/MX/Deployment_Guides/VPN_Concentrator_Deployment_Guide
Hi PhilipDAth
Thanks for the comment. But ASA is already installed at DC and working with other non-meraki branches. Is there no way to configure MX as spoke that they'll have VPN session only to ASAs in primary/secondary DC?
No.  You can configure firewall rules to block spoke to spoke traffic.
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
Your experiencing this dilemna because your network design is not appropriate for the solution being deployed.
