VPN is very slow
HaniAbuelkhair4
VPN is very slow
I have RAS windows server behind the Meraki, and we are using it as VPN server, using PPTP
All the users are connected with no issues, we have only one of the staff trying to connect and he can connect successfully but the problem is he is getting only 1-4Mbps download and upload is getting the full speed 10Mbps
His home internet speed is 400Mbps before connect to the VPN
When connect to the VPN the download speed is 1-4Mbps onlu
The main office where the VPN server is the ISP link is 300Mbps upload, and 300 Mbps download and its not congested
I created a client VPN using the Meraki MX and getting the same result of slow downloads (so the issue is not the server)
Tested the VPN to another location windows server and the speed was perfect
Checked the Merkai MX log nothing wrong, we disabled the IPS to check no change in performance
What could be the issue in the Meraki to cause this slowness
We have around 40 of the staff using the VPN with no issue, only this staff
Any suggestions what to check on the merkai ?
HaniAbuelkhair4
Any suggestion here ?
Is there is away to test the the download between both location to identify if its an ISP provider issue, like a software to be installed in one location and download from the other location ?
Any ideas ?
@HaniAbuelkhair4 it is something between the staff member's network and the office.  It could be one or more of:
  • Staff member's ISP peering with corporate ISP
  • MTU size issue at staff member's end
  • Port level restrictions at staff member's ISP
For the second you could try reducing the MTU value at the corporate side, it will make other connections a little bit less efficient, but might fix the one staff member.  For the others you'd need to have a good relationship with their ISP to get anywhere...
HaniAbuelkhair4
By any chance do you know any software that i can use to test the speed between the main office and end user home like install software at the head office and try to measure the speed from the end user home to confirm the issue ?
