VPN and Warm Spare
ylutigneaux
VPN and Warm Spare
Hello !
I have configured a VPN site to site between à MX105 and a MX68. It's working great.
I have tried to hade a second MX68 to do a warm spare. The warms spare is working great for Internet connection. I have only one internet connection, the both MX68 are connected by a switch to the conenction internet
But When i do a swap between my primary to my slave, the VPN connection is lost and don't restart even a long time.
I tried with Virtual IP adresse in warm configuration and without but it's the same problem.
Have you any idea of the problem ?
Have a nice day,
Yoann
KarstenI
Do both of your MX68 have a public IP? I've seen ISPs where the first device got the public IP from a /30 but the second only a private IP from a DHCP pool. This could break VPN connectivity.
And are you talking about AutoVPN or a manual IPsec config?
ylutigneaux
Hi Karstenl,
In fact i could identfy that the main problem come from Cellular connection. When i get out the SIM Card from my first Meraki it's working great.
I have made an AutoVPN configuration.
I am searching for some info on cellular conenction. I break my Warm spare to test with only one MX. I am able to get a VPN connection without SIM Card but not when i have SIM Card and Wan connected...
ylutigneaux
I Think i got it... I activate this "Do not create VPN tunnels over the secondary uplink unless the primary uplink fails." in SD-Wan configuration.
To my minf, MX is unable to connect VPN between the Cellular and Wan connection at the same time. So with this option, i activate Tunnel on cellular only when WAN1 come down.
Now it's working as i want.
Thanks for help
KarstenI
